Author: Subject: trumpets for 45s
2b_pablo
posted on 20/1/08 at 09:32 PM Reply With Quote
trumpets for 45s
can you use weber trumpets on dellorto carbs?
seen a few sets of weber trumpets on ebay quite cheap but no dellorto ones.
RD and Burton list seperately for dcoes and dhlas. £50 is for 4
cheers
skydivepaul
posted on 20/1/08 at 09:34 PM Reply With Quote
no they are a different fitting.
dellortos bolt on and webers slide into the carb body
http://www.smartideasuk.com
http://www.smartmapping.co.uk
HD CCTV
IP security systems
access control systems
2b_pablo
posted on 20/1/08 at 09:37 PM Reply With Quote
thats what I figured thanks!
I also need the little bar with the pop on joints to connect the linkage to the throttle body spindle. RD list a 6" long threaded bar with plastic ends do you just cut this to size as I think 6" is a little long. more like 4" tops on mine.
skydivepaul
posted on 20/1/08 at 09:47 PM Reply With Quote
not sure on that one, all the carbs i have always came with the linkage attached. not got any in the garage at the moment though so cant have a look for you.
HD CCTV
IP security systems
