ed_crouch
| posted on 20/10/03 at 09:48 AM |
BMW straight six (alloy block!!!) into an indy - will it go??
AS above, really, i *might* be getting a BMW M52 2.5 litre S6, tipping the scales at 120kg. 170BHP, 24 Valve, 4 valves Per Cyl. VANOS (variable valve
timing) on both cams. question is, will it go into a seven type engine bay??
My two worries are getting the sump and oil pickup shallow enough,
and the length of the engine.
Does anyone have any experience of this type of install.
I could use the locost plans and build a modified chassis...
anyway, expereinces of big engines in little cars would be apreciated.
Regards,
Ed.
| posted on 20/10/03 at 09:56 AM |
Hi Ed,
Check out Luegos straight six jag installation. Just click on locostbuilders and go back to the front page.
HTH
Nick
Metal Hippy
| posted on 20/10/03 at 10:42 AM |
If you're looking at an Indy I'd guess you have no chance.
If you want to buy a chassis look closely at the Luego Viento, otherwise you've got some research to do...
Search for posts by mustangsix, he's got some useful stuff and a possible chassis design on his website.
Rich.
Cock off or cock on. You choose.
ChrisW
| posted on 20/10/03 at 10:52 AM |
I know Luego have built a Viento with some kind of BMW st6 'M' engine. Don't know which car it was from tho. Go to their website
(click the logo above) go to Viento then 'new projects' for a pic.
Chris
My gaff my rules
