Author: Subject: 1.8 Blacktop - Bike Throttle Bodies
MKMike
posted on 27/1/08 at 12:23 PM Reply With Quote
Will GSXR600 throttle bodies suit the 1.8 Blacktop Zetec?
Do you use the main injectors on the throttle bodies?
If so what do you do with the second set of injectors on the throttle bodies?
Any modifications needed?
piddy
posted on 27/1/08 at 01:06 PM Reply With Quote
Hi.
I'm using them on a silver top work well.
Yes
I filled them with instant metal stuff.
You will have to space the T/B's to suit or get the inlet manifold made to take them as they are.
[Edited on 27/1/08 by piddy]
MKMike
posted on 27/1/08 at 10:43 PM Reply With Quote
Thanks for the info above.
Where did you get your manifold made?
What ECU did you use?
piddy
posted on 2/2/08 at 07:16 PM Reply With Quote
Manifold from some chap on e bay Can't find his info anymore.
Mega squirt ecu
I would go Emerald if I was to do it again
