Author: Subject: zetec motor
les g
posted on 31/1/08 at 08:30 PM Reply With Quote
zetec motor
hi everybody
i recently posted a q. about a dohc engine from my donor into my build its not written in stone that i,m going to use it and the almost unaminous verdict was to chop it in for a zetec !!!!
ok next q. which zetec 1.8 or2.0 and why and why are people using 1.8,s with 2.0lcams i must have missed something
please reply i really am grateful of the feedback i have already had you all seem like a good bunch
cheers les g
ps. anyone know how to contact triton
r1_pete
posted on 31/1/08 at 08:33 PM Reply With Quote
have a look at www.zetec-cat.co.uk for engine specs.
Generally 1.8 is about 115 PS and 2.0 about 136 PS, a 1.8 on 2.0 cams about 130 PS, with throttle bodies or bike carbs anything up to 180 PS is quite easily achievable.
Pete.
P.S. I got £30 for my DOHC from a bloke with a cracked head sierra, the most common problem.
[Edited on 31/1/08 by r1_pete]
big_wasa
posted on 31/1/08 at 09:27 PM Reply With Quote
I gave mine away and was greatfull the guy collected
2l zetec Has more torque. 1.8 is cheap
posted on 31/1/08 at 09:43 PM Reply With Quote
2.0 Litre water pump revolves the wrong way, sump is too big as is the flywheel.
To get a 2.0 to work with a type 9 you need all of them bits off a 1.8.
Thats why its easier to just put 2.0 cams in a 1.8 and get about the same bhp.
r1_pete
posted on 1/2/08 at 09:55 AM Reply With Quote
Another thing, up to 98 the phase 1 & 2 engines, identifyable by alloy cam cover, and water pump directly above the crank, hydraulic valve lifters - easy cam changes - referred to as Silvertop.
Post 98, plastic cam cover, different block, water pump offset to the exhaust side, all water pumps rotate counter clockwise (the wrong way - need an idler or special impeller), two peice sump. Solid shimmed lifters, and I'll tell you what cam changes are like after this weekend when I pick my new ones up and measure the shims etc. - referred to as Blacktop
