Simon
| posted on 4/2/08 at 02:09 AM |
R V8 water pump end, heater hoses
Peeps,
I'm using the pipework for the (production car) heater to cool my turbos.
They've been blanked off on mine and I can't remember how they should go.
There are two pipes sticking out the front under the manifold.
Pics would be a great help. Can't find any specific pics in Haynes book, the R V8 tuning books or on the web.
Cheers very much
Simon
robinj66
| posted on 4/2/08 at 08:40 AM |
On the SD1 engine, one connector was at the back of the (standard, water filled) manifold and the other was a small pipe off the water pump pipe, via
a metal pipe which ran under the centre of the inlet manifold.
Hopefully the pictures show it better than I can explain
[img] [/img]
[img] [/img]
| posted on 4/2/08 at 10:22 AM |
correct. there are two elongated S-shped hoses that fit from the two pipes to the back of the water pump.
as ^^^ says, one of the pipes is a steel pipe that runs under the manifold.
The same at the back - again two outlets that go to the heater.
The water pump connects to radiator - that is the inlet and one of the hoses taps off that; in case you need the flow to be directional.
