sgtbrierley901
posted on 5/2/08 at 06:02 PM |
ford dohc gearbox
hi there
does the type 9 gearbox fit straight onto an 2.0 l dohc engine ?
i have joined the two together but im not sure its right
thanks in advance
stu
r1_pete
posted on 5/2/08 at 06:08 PM |
MT75 fits zetec, type 9 fits the same Zetec, so cant see a problem with your config.
BTW 2.0L DOHC's aren't a popular engine on here, expensive to maintain, and a heavy lump for not a lot of power, as I found out, and went
Zetec.
big_wasa
Done the other way with the Mt75 box on to say a zetec you need a spacer on the thrust bearing to make up the gap left by the super chunky Dohc fly
wheel.
Using that logic a standard bearing in a type 9 would be hard up to the clutch with no room for ware ? ![](/images//smilies/smile.gif)
r1_pete
posted on 5/2/08 at 06:16 PM |
^^^^^ good point forgot about that flywheel, better suited to an olympic weight lifting bar...
sgtbrierley901
posted on 5/2/08 at 06:21 PM |
ok thanks
that might explain why the release arm is really stiff
ok im thinking maybe i should change my engine plan
les g
posted on 5/2/08 at 06:34 PM |
dohc
westfield do a spaced bearing ready to go
les.g
big_wasa
posted on 5/2/08 at 07:02 PM |
les.g
Yep to go from the Mt75 box to say a zetec But not a T9 to a Dohc.![](/images//smilies/wink.gif)
scotty g
posted on 5/2/08 at 07:05 PM |
A maye of mine has coupled the yupe 9 to the DOHC in his modified Dutton Sierra, He had to shave about 10mm off the flywheel but apart from that it
was an easy job and it runs fine with it.
here it is
![](/galpreviews/a687691-Image002.jpg) ![Rescued attachment Image002.jpg](/gallery/a687691-Image002.jpg) Rescued attachment Image002.jpg
sgtbrierley901
posted on 5/2/08 at 07:59 PM |
ok so no matter what im going to have to remove engine again damn it
so is it better to go for an mt75 box or
im still toying with the idea of changing engine?
scotty g
posted on 5/2/08 at 08:10 PM |
the MT75 box is a bit wider than the type 9 and doesn't always fit into locost's. Take some measurements first but if it fits then why not
use it, its a good smooth gearbox and stronger than the type 9.
Mole
posted on 5/2/08 at 08:49 PM |
If you have to remove that engine any way why put it back![](/images//smilies/wink.gif)
sgtbrierley901
posted on 5/2/08 at 08:52 PM |
yes thats what i was thinking aswell ill have to decide wether pinto or zetec its an cost thing really
Mole
posted on 5/2/08 at 08:55 PM |
Zetec is really cheap, I doubt you could get a pinto cheaper. I paid £200 for mine delivered and I'm sure now I could have paid less.
sgtbrierley901
posted on 5/2/08 at 09:01 PM |
yes i have seen an 1.8 zetec on ebay for 160 with shortned sump and mounts but no carbs or inlet manifold or ecu
is that good value?
Mole
posted on 5/2/08 at 09:04 PM |
With shortned sump that looks pretty good. No one uses the stock ECU and I got my bike carbs for £40, make and manifold and away you go. ![](/images//smilies/bigsmile.gif)
sgtbrierley901
posted on 5/2/08 at 09:10 PM |
b******s its been sold for £90
ahhhh
