irvined
| posted on 7/2/08 at 12:46 PM |
Type 9 Input Shaft dimensions
Hello,
Anybody happen to have a type9 laying around?
I replaced the gearbox on my seven last weekend after an oil leak on the way to France led to a slightly catastrophic failure of the transfer gears
leaving me with only 4th.
Broken gears
Anyway after much faffing around with lhd/rhd bell housing i think I'm good to go - ie, it all bolts up ok.
As I'm now being paranoid, i want to know what the distance between the end of the input shaft and the end of the bell housing is on a standard
5 speed non-v6 box.
This one looks like it comes almost to the entire length of the bell housing, whereas I'm sure the previous one stopped about an inch before
hand, but like i said i hope I'm being paranoid.
My theory is that if it bolts up and still turns then it wasn't the wrong one.
[Edited on 7/2/08 by irvined]
http://irvined.blogspot.com
Hammerhead
| posted on 7/2/08 at 12:49 PM |
As far as I know the end of a standard type 9 is level with the bell housing. I think the V6 extends beyond the bell housing.
irvined
| posted on 7/2/08 at 12:52 PM |
*PHEW*
I can continue crossing my fingers for some dry or at least not quite so wet weather this weekend after all.
Dusty
| posted on 7/2/08 at 04:23 PM |
Just measured mine as the engine is out at the moment and the tip is about 2mm short of the bellhousing to block face.
