Author: Subject: Throttle cable problem on a bike carb
posted on 9/2/08 at 04:26 PM Reply With Quote
Now that my bike carbs are mounted I have a new problem to sort out. The throttle cable comes off the top of the carbs, and even with a proper 90-degree bend it comes up higher than the bonnet line. The fixing can be seen on the nearest edge of the carbs, just above the TPS.
First fit of bike carbs
Has anyone here modified carbs like these (CBR600) so that the throttle cable is fixed in a different position?
I'm thinking that I'll have to come off the bottom of the carbs to get rid of all clearance problems.
dave1888
posted on 9/2/08 at 07:22 PM Reply With Quote
Would it be possible to fit/build some kind of rocker to the carbs so the cable is attached at the bottom and pulls the linkage up.
posted on 9/2/08 at 07:44 PM Reply With Quote
Thinking it over, I might build in a pulley to turn the cable through 180 degrees - still mulling it over!
posted on 9/2/08 at 08:38 PM Reply With Quote
David have you got room for a "conduit" a 90 degree bend in a piece of steel tubing similar on some bike throttle cables at the twistgrip end? Mel
Bob C
posted on 9/2/08 at 09:21 PM Reply With Quote
ON the R1 carbs, there are 2 cables (push/pull) so they are attatched to like a circular pulley on the throttle spindle. So on my car I just used 1 cable & it went 3/4 the way round the throttle spindle thing. The cable outer went to a plate bolted between the bottom of the front two carbs. Sorry if that sounds a bit convoluted - & may all be completely irrelevant to you. But I'll try & find a picture
http://freespace.virgin.net/bob.carter/images/tophose.jpg
it can just be seen on there
Bob
gazza285
posted on 9/2/08 at 09:27 PM Reply With Quote
Man with ability to make this;
Catch-tank cap
Catch-tank cap
Needs help with a bit of a linkage problem?
givemethebighammer
posted on 9/2/08 at 09:29 PM Reply With Quote
I just have a 90 degree piece of tube on my blackbird (same as yours except size) carbs. I have however seen people use these:
http://www.chainreactioncycles.com/Reviews.aspx?ModelID=1802
for getting round the problem
posted on 9/2/08 at 09:55 PM Reply With Quote
Mel,
The throttle cable kit I bought off ebay has a few bends - but they're physically quite large so there's little benefit. Previous experience of bends and the resistance they can cause makes me reluctant to go for anything more extreme.
Gazza,
I was looking for a quick fix, rather than me having to engage brain again!
Currently the pulley fixed to the existing plate is looking favourite...
cheers,
[Edited on 9/2/08 by David Jenkins]
gazza285
posted on 10/2/08 at 12:07 AM Reply With Quote
Originally posted by David Jenkins
Gazza,
Wasn't that one on the back of England's Glory?
"Ensure brain is engaged before putting mouth into gear"
posted on 10/2/08 at 11:41 AM Reply With Quote
Most of the time I prefer to tick along in neutral...
Schrodinger
posted on 10/2/08 at 10:14 PM Reply With Quote
Or something like this
http://www.chainreactioncycles.com/Models.aspx?ModelID=271
But try any bike shop theyare used on most V brakes
[Edited on 10/2/08 by Schrodinger]
Keith
Aviemore
