| posted on 9/2/08 at 04:32 PM |
Filter King regulator
Can anyone tell me how to adjust the pressure on a Filter King regulator like this?
I'm certain it's to do with the shiny nuts (ooer!) on the top, but I have no idea which one is the adjuster and which is the lock-nut, and
in which direction to turn it for more or less pressure.
cheers,
iank
| posted on 9/2/08 at 04:53 PM |
Under the chrome dome nut there should be a grub screw that does the adjusting. They come set to 2.5-3.0 PSI from the factory IIRC.
If yours has the gauge just adjust away.
Anonymous
| posted on 9/2/08 at 05:31 PM |
Didn't you have a bike pump David? if so you probably don't need the regulator. ISTBC
| posted on 9/2/08 at 06:47 PM |
I changed my mind - I've now got a Facet pump, hence the filter/regulator.
