Author: Subject: Starter ring
MikeLR
posted on 14/2/08 at 02:32 PM Reply With Quote
Starter ring
Just a cautionary post. The starter ring has become separated from the flywheel on my Tiger. It was heat shrunk on, probably needed to be tack welded as well.
With a bit of luck this should be able to be done insitu.
Is this a common problem ?
Mike
Mr Whippy
posted on 14/2/08 at 02:39 PM Reply With Quote
don't tack weld, the ring is hardend and will be damaged from the heat of the welds making it more likely to shatter at speed.
Put the new ring in the oven at it's maximum heat and then place it quickly on to the flywheel. Let cool naturally.
posted on 14/2/08 at 02:40 PM Reply With Quote
The ring will be far to hard to get a weld on without crystallisation. Be careful!
nib1980
posted on 14/2/08 at 02:54 PM Reply With Quote
not to mention potentially unbalancing the flywheels, an shafting your engine
speedyxjs
posted on 14/2/08 at 03:11 PM Reply With Quote
Dont forget the oven gloves
r1_pete
posted on 14/2/08 at 03:18 PM Reply With Quote
Thats good cos I feared I'd caught mine re-drilling the clutch bolt holes....
Mr Whippy
posted on 14/2/08 at 03:57 PM Reply With Quote
To remove a starter ring a small hole is drilled in it and then a blow with a chisel cracks the ring open. So any damage to it by accident could cause a future break up.
MikeLR
posted on 14/2/08 at 05:47 PM Reply With Quote
Might just be opening a can of worms here !!
Have spoken to two engine tuners this afternoon and they both tack weld starter rings on, one said quote " we always tack weld in high compression engines and large engines. four weld diagonaly opposite each other"
Is the disintigration of the ring more of a theoretical problem ? would it not more likely to break up on starting ? Has anyone had a ring break up ?
Thanks for your comments.
Getting near " make my mind up time " !!
Mike
posted on 14/2/08 at 06:01 PM Reply With Quote
The starter ring on my brothers ultra-light steel flywheel for his mini was tacked on which I wasn't overly impressed with. The welds cracked anyway and the starter ring moved over jamming the starter so I suspect the flywheel was undersized for the starter ring in the first place.
Liam
posted on 14/2/08 at 10:21 PM Reply With Quote
The ring gear that i've fitted to my custom ally flywheel was originally fitted to a torque converter flex plate rather than a flywheel since it was from an auto. That was tack welded and that's a production car item.
In the world of ally flywheels, the most common way to retain the ring gear is with flange headed fastenings (or just dome heads with washers). The fasteners are actually fitted to the flywheel shoulder but the heads/washers overlap onto the ring gear. Usually there is a counterbore that the fastener is recessed into. This counterbore obviously takes a small notch out of the ring gear, but this doesn't seem to be a problem. This stops the ring gear from both slipping round and walking off the shoulder.
Less common, but often seen is the method of TIG welding tabs onto the ring gear that fit into rebates in the shoulder of the flywheel. These tabs are then bolted to the flywheel. Like the production item above this welding of the ring gear is obviously acceptable if done properly. In fact one of the ally flywheels i've seen with the welded tabs ring gear retaining method is a production Ford Racing one for a Mustang Cobra. Still, my preference would be the flange headed fastener method above.
What you certainly wont see is a hole drilled through a ring gear for a dowel or fastener.
Liam
