Author: Subject: temp gauge
:{THC}:YosamiteSam
posted on 19/2/08 at 10:20 PM Reply With Quote
temp gauge
just doing some prelim wiring - zetec silver top 1.8.. one question..
ecu needs a sensor to tell it the water temp - use the themostat housing connection on the top - so where does the engine temp gauge connection go? double up to the same connection? if the ecu is being told the temp it will do for the gauge - am i right? i have seen the ally connectors for the top hose where a probe is inserted to for it - is that the only option? more money???????? lol ???
also sorry second question what is the lower connection for on the thermostat housing?
cheers guys
posted on 19/2/08 at 10:55 PM Reply With Quote
Zetec thermostat has the big sensor on the top I believe is for the ECU and a smaller one on the side for the temp gauge...
Thats what mine looks like anyway
saigonij
posted on 20/2/08 at 08:30 AM Reply With Quote
thats correct.
:{THC}:YosamiteSam
posted on 20/2/08 at 05:47 PM Reply With Quote
cool - will now try to source a plug for it.. anyone know where i can get one??????
paulf
posted on 20/2/08 at 06:57 PM Reply With Quote
You must use the lower sensor for the gauge, dont try and run gauge and ecu from the same sensor as it will cause them both to work incorrectly.
I think the lower sensor is just a spade terminal, if not a local scrapyard is the easiest bet.
Paul.
