Author: Subject: Any CVH experts?
TimC
posted on 21/2/08 at 09:05 AM Reply With Quote
Any CVH experts?
Hi Guys
I presently run a K-plate 1600CVH Sierra as my tin-top. I have no real point of reference but I'm sure it's not right. It seems to run far too rich, doesn't pull cleanly and the MPG is a pathetic 21mpg!
I've read the Haynes book of words and it seems to suggest that everything is run off sensors feeding the EEC IV ECU so there's no other way to adjust the mixture. Can any issues by diagnosed?
Any help gratefully received.
TC
Mr Whippy
posted on 21/2/08 at 09:08 AM Reply With Quote
does it have a lamba sensor? If they stop working it will put the mixture out.
Faulty temp sensor can also make it run rich as it thinks the engine needs more fuel, like a carbs choke setting
[Edited on 21/2/08 by Mr Whippy]
posted on 21/2/08 at 09:11 AM Reply With Quote
1.6? sure its not a 1.8
If its defo 1.6 it will be well tired and the pathetic mpg will be cause its struggling to pull 2 tons of fat Sierra around!
Mr Whippy
posted on 21/2/08 at 09:16 AM Reply With Quote
If it was my car I'd have tossed the fuel injection in the bin long ago and stuck on a nice duel choke webber, there only about 100 quid new.
russbost
posted on 21/2/08 at 10:36 AM Reply With Quote
CVH's had a nasty habit of bunging up all their oil breather ways with gunge, would suggest cleaning all upper & lower breathers out as this can completely throw mixture off particularly at idle. Assuming it's got a CAT which it should have at that age most likely culprit is a knackered lambda sensor (possibly caused by passing oil across it - back to the breather problem!). They also suffered with TPS getting worn track.
Get a MoT garage to bung it on their 4 gas & see what's coming out of the back. The car should be capable of aroud 30 - 35 on a run, 25 - 30 round town. HTH
posted on 21/2/08 at 11:13 AM Reply With Quote
check the coolant temperature sensor and the thermostat is working ok.
TimC
posted on 21/2/08 at 03:35 PM Reply With Quote
Good shout that. The Haynes talks about the seal for the thermostat. What does it look like? WIll it be a dealer-only part?
