Author: Subject: Gap between oil pickup pipe and sump floor
scotty g
posted on 26/2/08 at 05:19 PM Reply With Quote
hi all, just about readyto put on my shortened sump, only need to modify my oil pick up pipe.
Does anyone know the size of the gap between this and the bottom of the sump?
procomp
posted on 26/2/08 at 05:25 PM Reply With Quote
Hi on most for competition use a gap of around 8-10mm is usually what it seen.
HTH cheers Matt
PaulBuz
posted on 26/2/08 at 05:27 PM Reply With Quote
I've got around 8-9mm.
It seems to run alright
Paul
scotty g
posted on 26/2/08 at 06:50 PM Reply With Quote
forgot to mention that irs a 1.8 zetec, don'y know if it makes any difference.
scotty g
posted on 26/2/08 at 08:08 PM Reply With Quote
Thats pretty much the method i was going to use if nobody could give me an answer.
20mm seems quite a lot but hey if thats what Ford reckon then who am i to argue!
posted on 26/2/08 at 08:44 PM Reply With Quote
As long as the pick up is not too close to the sump and is immersed in oil at all times you shouldn't have any problems.
posted on 26/2/08 at 08:47 PM Reply With Quote
Eh?
Surely you want the pick up fully immersed at all times to prevent oil starvation?
snapper
posted on 26/2/08 at 09:37 PM Reply With Quote
How close is too close?
My sump has bowed up after the welding cooled and the pickup may be quite close.
I eat to survive
I drink to forget
indykid
posted on 26/2/08 at 11:01 PM Reply With Quote
Eh?
are you mid drowning your sorrows nick?
i'm pretty sure that's what your quotation says.
tom
procomp
posted on 27/2/08 at 07:57 AM Reply With Quote
Hi For TIN sumps Ie not cast ali. A competent engine builder would put a couple of small spacers to the required length welded to the pickup. So that it could not sit against the floor of the sump if it should happen to be squashed ect.
Cheers Matt
posted on 27/2/08 at 07:03 PM Reply With Quote
Eh?
What does my reply say??
posted on 3/3/08 at 11:56 AM Reply With Quote
Eh?
Sorry
Should learn to read a bit slower and engage brain before replying!
