Author: Subject: pinto webber carb ( return )
zzr1100rick2
posted on 27/2/08 at 07:39 PM Reply With Quote
Hi have a webber carb to fit to a pinto and it has what looks like a feed and a return pipe connected to the float chamber
Question is do i have to use a return or would a SU type electric pump feeding the carb be ok
cheers Rick
phoenix70
posted on 27/2/08 at 08:04 PM Reply With Quote
it unusual to have a return on a carb'ed car, normally it is only FI that need a return, but you will need a pressure regulator to reduce the pressure to the carb's
ditchlewis
posted on 27/2/08 at 08:16 PM Reply With Quote
no i've had one too. i blocked off the return and it worked ok.
ditch
r1_pete
posted on 27/2/08 at 08:33 PM Reply With Quote
The return was used on mechanical pumps, it returned to the feed pipe on the tank side of the pump. I was told it was to prevent premature failure of the disc valves in the pump due to over pressuring.
Quite safe to block it off.
