Author: Subject: Phase 2 Windage Tray on a Phase 3 engine
r1_pete
posted on 28/2/08 at 09:21 AM Reply With Quote
In order to fit the phase 2 windage tray on my Phase 3 zetec, I had to space the double ended bolts, between the bolt head and main cap, the ph3 main caps are shallower than ph2. I used large high tensile bolts as the source of material. Anyone see a problem with this before I seal everything up?
Cheers.
Pete.
jacko
posted on 28/2/08 at 06:19 PM Reply With Quote
Can you lock wire at all ?
