Author: Subject: ecotec inlet manifold
blakep82
posted on 28/2/08 at 08:32 PM Reply With Quote
can't remember if i asked this before and can't find anything on the search
whats the best way to shape the tubes for these flanges or do i just weld the tubes on round? and what length should i make the runners?
zzr1100 carbs on a 2.0 ecotec
________________________
posted on 28/2/08 at 08:47 PM Reply With Quote
A vice or careful application of the percussive spanner should do the trick. As long as the inside circumference of your port runners is the same as the ovalised port you should have a nice smooth transition to the throttle bodies.
blakep82
posted on 28/2/08 at 08:51 PM Reply With Quote
for some reason the pic doesn't work... the ports aren't oval
here's another one
jacko
posted on 28/2/08 at 09:11 PM Reply With Quote
HI have a look in my photos under zx9r carbs you will see how i made my manifold + the jig i used to make it
Jacko
