charlierevell
| posted on 1/3/08 at 04:28 PM |
Clunk, Bang... Hmmm what was that?
Hi Guys,
been out for a good drive today, excellent weather for a good blast!
However when coming back into town, rolled of the throttle into 3rd or 4th had a BIG clunk and rattle. Put the clutch in let it out and all was fine
with a noise that sounded like something clunking down the Trans tunnel.
No oil lost, nothing looks wrong and it now seems to run fine and change thru all the gears ok.
Box was rebuilt by AB performance over christmas.
Its a 954 Blade lump.
Any thoughts on what it could be???
Thanks all...
Tango orange is an 'IN' colour!!
SeaBass
| posted on 1/3/08 at 04:29 PM |
Stone on the road under the car?
r1_pete
| posted on 1/3/08 at 04:31 PM |
balance weight coming off the propshaft?
charlierevell
| posted on 1/3/08 at 04:33 PM |
Both good ideas.... it doesnt seem to be anymore unbalanced! I like the stone idea it doesnt seem so expensive!!!
SeaBass
| posted on 1/3/08 at 04:40 PM |
I've had a few like that. I've stopped - checked everything over. I normally convince myself it's a critical nut or bolt sheared or
come loose. It never is though...
Benzine
| posted on 1/3/08 at 04:48 PM |
earthquake?
Guinness
| posted on 1/3/08 at 04:51 PM |
I usually find it was whatever tool I left under the bonnet
Usually on top of the gear box, or on the flat bit over the footwells.
Mike
| posted on 1/3/08 at 05:11 PM |
Yup. Tool under the bonnet. Last time I got back from a blat, went to adjust a bolt that keeps on working loose and found the spanner sitting in the
engine bay in the same place I left it after the last repair!!!
ruskino80
| posted on 1/3/08 at 05:32 PM |
quote: Originally posted by Benzine
earthquake?
 brilliant
charlierevell
| posted on 1/3/08 at 05:44 PM |
So Brilliant you put it twice!!! hehe
Yeah the missed gear was a worry, but normally it just hit a false neutral somewhere, strange!
| posted on 1/3/08 at 06:26 PM |
Check your nuts - prop adapter. Central bearing... etc - you can never be too sure it was a brick/pebble...
charlierevell
| posted on 1/3/08 at 06:32 PM |
Theres a tiny bit of play in the prop, no play in the bearing and the bolts are both there. Cant see the prop adapter.... should i be able to? or is
it behind the seal on the prop?
Had the scuttle off and looked town the tunnel, looked from below too and cant see anything. Prop bolts are all still there on the UJ.
Toady1
| posted on 4/3/08 at 04:32 PM |
Hi charlie, it sounds like you may not have got it into gear properly if you ask me, which as said is one of the best ways to ruin the gears! This
was evident when Andy rebuilt it. If i were you, id look into getting a better gear shifing set up fitted, and possibly using cables, or another big
gear box bill could be looming round the corner! Im still around if you want to ask any info ever! lol!
charlierevell
| posted on 10/4/08 at 10:12 AM |
Update... got it to do it again in exactly the same place, very odd! Its the gears not meshing from what i can tell, only does it when using the
clutch too.
Answer is dont use clutch and its all fine! Worst i get with no clutch is a false neutral, and thats much better on the ears!
