Author: Subject: Locost Zetec Questions
brown_d9
posted on 1/3/08 at 05:07 PM Reply With Quote
Hello All, my dad has some questions, unfirtunately he is still in the stoneage and is bearly able to use a pocket calculator, so im going to ask them on his behalf.
First of all we have built a Locost from the Ron Champion book with the back end from a Tiger Avon (We wanted the IRS)
It is going to be fitted with a 1.8 Zetec fitted with a set of motorbike carbs and running through a type 9 gearbox and a sierra XR4X4 Diff.
The questions we would really appreciate an answer to are as follows...
Where is the best place to get a cheap set of exhaust headers?
What starter motor will be best for the above installation>
Which side of the engine is the alternator mounted and which car is the alternator from, which belt?
What clutch,flywheel and thrust bearing is best?
I hope someone out there has some similar installation as we have, and would really appreciate your help.
Thanks in advance.
Dan
scotty g
posted on 1/3/08 at 05:15 PM Reply With Quote
Hi mate, i'm getting my exhaust from GTS.
The starter motor is from either the DOHC or the CVH sierra's.
You can use the flywheel/clutch from the zetec but i think the thrust bearing is a sierra job but i could be wrong on that.
UncleFista
posted on 1/3/08 at 05:22 PM Reply With Quote
There's loads of info on here, the search function is borked though, so instead of a space in between search words, insert a "%" between 'em.
I have a similar setup to you, plenty of my pics HERE
Dunno about the best place for exhaust manifold, but the cheapest is your local scrappers and get one off a mondeo/escort
We used a starter from a 1.8 CVH (Sierra).
Our alternator is mounted on the drivers side, it's a small one from a small Jap car (Micra?) at the scrappers with a ribbed pulley welded on.
ready to fit
ready to fit
Clutch is a standard 1.8 Zetec, on a 1.8 zetec flywheel (you then get the crank sensor and trigger, no need for aftermarket one for your sparks) release bearing is from 2l Pinto (Sierra or Capri).
You'll also need a Pinto spigot bearing.
Edited to add THIS LINK which was invaluable when we were converting
HTH
[Edited on 2/3/08 by UncleFista]
Tony Bond / UncleFista
brown_d9
posted on 1/3/08 at 05:31 PM Reply With Quote
Thats great thanks, keep em coming!
bob
posted on 1/3/08 at 05:38 PM Reply With Quote
This link to a previous thread should give you lots of info.
zetec link
jacko
posted on 1/3/08 at 05:50 PM Reply With Quote
Tim Windmill on here tried different places for a exhaust manifold and ended up getting one from Westfield his was for a zetec 2l black top have a look in his photos under sva it's the light gray car
Jacko
[Edited on 1/3/08 by jacko]
posted on 1/3/08 at 08:00 PM Reply With Quote
Check my blog out, you might find some advise in there
Chippy
posted on 1/3/08 at 10:48 PM Reply With Quote
This is quite useful for all the info.
http://www.gibbs111.fsnet.co.uk/eng_gear_comb.htm[/url]
Hope that helps, Ray
scutter
posted on 2/3/08 at 08:14 AM Reply With Quote
I ordered an exhaust through GTS took 41/2 months to turn up and only after i phoned every 2 days, i finally got the name of the company who was making it and got them to send it direct.
They are Tube engineering on 01673 862286, Mike's the man to talk to.
The exhaust comes straight out the head, which should be fine if you've a book height chassis, think he said it was for a Leugo Velocity.
ATB Dan.
