Author: Subject: It lives
triumphdave
posted on 1/3/08 at 07:24 PM Reply With Quote
It lives
After the lengthy delays due to the Turbo shop manifold saga,I finally fired up the C20xe for the first time after the rebuild.After a couple of adjustments to the R1 carbs it ticked over like a dream.But after about 5 mins while I ran the cams in the fan cut in, am I being paranoid or do you think it should of run for longer before getting that warm.I spent most of the morning getting airlocks out of the cooling system,pretty sure I have got all the air out.
chrsgrain
posted on 1/3/08 at 07:29 PM Reply With Quote
Cool! Well done....
When mine was running on completely standard kit and a polo radiator and the cooling set up as SBD with a heater (yes I'm soft!) it ran for a good 15 mins before the fan cut in... hope that helps.
Chris
PS thanks for the pictures by the way
RichardK
posted on 1/3/08 at 07:30 PM Reply With Quote
Have you checked your ignition timing, maybe retarded too much?
Gallery updated 11/01/2011
triumphdave
posted on 1/3/08 at 07:34 PM Reply With Quote
Its running at 10btdc on tick over (limp mode for the edis unit)
triumphdave
posted on 1/3/08 at 07:38 PM Reply With Quote
If you need any more let me know.
I was looking at yours in your archive,the chassis seems quite a bit different to mine,I would be interested to see some more photos if you have them.
RichardK
posted on 1/3/08 at 07:44 PM Reply With Quote
Not timing then..
Try boiling your temp switch with a multimeter attached to see at what temp continuity changes. Would be my first suggestion then, if you're sure there are no air locks.
Rich
Schrodinger
posted on 1/3/08 at 10:15 PM Reply With Quote
You could also be running a bit lean which could cause overheating, What rad are you using and where is the fan switch in the system?
Keith
Aviemore
triumphdave
posted on 1/3/08 at 11:18 PM Reply With Quote
The mixture was spot on stoic a thingy.The rad is the standard Dax supplied one think its out of a Cortina or Escort.The fan switch is in the top hose just before the rad.
