Author: Subject: facet fuel pumps?
ANDYSHORT
posted on 5/3/08 at 09:53 PM Reply With Quote
facet fuel pumps?
can anyone tell me the difference between a solid state pump and a interupter ie silver/red top pump and which is best for a bec and why!
posted on 5/3/08 at 09:59 PM Reply With Quote
Can't help you with the differences between the two types of pump but why not use the standard fuel pump from the bike?
Phil
worX
posted on 5/3/08 at 10:42 PM Reply With Quote
I too cannot help I am afraid, but I am posting just to reiterate Phil's advice - go for the pump from the bike...
robinj66
posted on 5/3/08 at 10:51 PM Reply With Quote
I'm not 100% sure but I think the solid state pumps just keep going as long as power is connected but the interrupter pumps go into an "idle" mode until fuel needs to go through the pipes
turbodisplay
posted on 5/3/08 at 10:54 PM Reply With Quote
I think you will find that it referes to the type of system used to generate the pumping action.
Solid state uses transistors to create an osciliating magnetic field, interrupter a mechanical switch mechanism.
Solid state is better as it is more reliable.
Darren
DarrenW
posted on 5/3/08 at 11:04 PM Reply With Quote
All i can say from experience is that using a red top with a 38dgas via a regulator overloads the floats and result in a heart stopping fire in the carb
Use pump matched to the system. Bike pump with bike carbs works very well indeed.
posted on 6/3/08 at 10:42 AM Reply With Quote
All pumps these days even Burlen SU pumps have solid state (Hall Effect) switching.
I suspect little square Facet/Bendix pumps use plunger rather than a diaphram to pump the fuel.
http://www.completeautomobilist.com/parts/fuel+system/
