Hugh_
| posted on 8/3/08 at 10:37 PM |
Ideas for removing stubborn silencer
I've had a rattle from the near side of the Fury for a while, and today decided to investigate it.
It transpired that it was a rivet holding the end of the silencer on which had come adrift and was rattling around the silencer which I've
removed. However in the process I realised the wadding is much to densely packed so tried to get the silencer off so I can remove what wadding I
haven't been able to get out so far.
The clamp came off easily, however the silencer will not! I've tried wiggling it, twisting it, heating it, WD40 (must remember not to start car
in garage next time I go out!), hitting it with a rubber mallet, and finally using the pneumatic hammer/chisel thing. It simply won't move.
Any ideas or suggestions appreciated, obviously I'd rather not destroy the thing as its a decent repackable one so not cheap!
[Edited on 8/3/08 by Hugh_]
gregf27
| posted on 8/3/08 at 10:54 PM |
try heating up some engine oil and pouring it onto the edge of your can, might be enough to free it up?
idea nicked from salvage squad tv programme , when they used it to free up a seized engine. no damage to your can either
Mr Whippy
| posted on 8/3/08 at 11:15 PM |
normal hack would be to cut a slot in the tube to let the joint expand, done on the side that faces the car with a dremel that should so the trick.
The Exhaust clamp would cover the slot anyway.
adithorp
| posted on 8/3/08 at 11:17 PM |
Beat around the join with a hammer. Shock from that will break up any corrosion and will also beat out any crimping from the clamp. On the plus side
you won't see any damage once the sill goes back on.
adrian
| posted on 9/3/08 at 01:12 PM |
adrian
My dad taught me this trick and it's always worked for me.
adithorp
| posted on 9/3/08 at 03:57 PM |
So did mine! It works several times a week for me.
adrian
| posted on 9/3/08 at 04:05 PM |
adrian
Find it works better if you use 2 hammers, one as an anvil and the other to hit the pipe.
Hugh_
| posted on 9/3/08 at 08:37 PM |
Cheers for the replies, muchos beeting with a hammer and WD40 over night eventually got the damn thing off. Now the baffle won't shift,
currently employing similar techniques, I'm sure I'll get there eventually!
