Snuggs
| posted on 10/3/08 at 05:39 PM |
Oil cooler
I am fitting an oil cooler and can't decide which way up to fit it
I have found many pics of installations and some have the connection pointing downwards and some upwards.
Which way is best ?
http://www.topcashback.co.uk/ref/snuggstcb
Spider pig, spider pig, does whatever a spider pig does.
I doubt therefore I may be.
Luposlipophobia : Fear of being chased by wolves around a freshly waxed kitchen floor, while wearing only socks on your feet.
My mind not only wanders, sometimes it leaves completely!
http://www.venganza.org
http://www.jesusandmo.net/
http://www.snuggs.co.uk
Jon Ison
| posted on 10/3/08 at 05:47 PM |
I'll stick my neck out, not sure there is a right and wrong way as the oil is pumped around under pressure anyway ?
Maybe the purist would say in at top out at bottom like a radiator ?
I too have seen them all ways and have fitted them either way to whatever suited at the time.
ravingfool
| posted on 10/3/08 at 05:50 PM |
Have to agree with Jon about it not mattering, despite mainly seeing them mounted with the connections at the top.
If you're got the room though why not mount it with the connections underneath to help with draining the system? Or do you risk air locks if you
do that?
Fred W B
It makes sense to me to have the connections on the top side, so that the cooler is always full of oil.
Fred W B
[Edited on 10/3/08 by Fred W B]
Snuggs
| posted on 10/3/08 at 05:56 PM |
Cheers guys
I am going to mount it with the connections at the top cos it is easier.
Clive
Paul (Notts)
| posted on 10/3/08 at 05:59 PM |
Clive,
how close are you to having the new engine up and running.
Paul
Snuggs
| posted on 10/3/08 at 06:12 PM |
Hi Paul,
Another week and it should be running.
Would have been sooner but I was waiting for the new gearbox.
Clive
