jimbona2
| posted on 10/3/08 at 05:58 PM |
oil filter
can anyone say what oil filter fits the avon with a 2litre zetec? (not much room down there!)
thanks
r1_pete
| posted on 10/3/08 at 06:17 PM |
I understand the renault 5 gt turbo is the right thread and only about 60mm tall.
whitestu
| posted on 10/3/08 at 06:30 PM |
I'm using the Renault 5 one.
stu
big_wasa
| posted on 10/3/08 at 07:01 PM |
R5 Turbo just change it more often
Danozeman
| posted on 10/3/08 at 07:21 PM |
R5 turbo on my zetec.
Dan
SeaBass
| posted on 10/3/08 at 07:37 PM |
I had a good look around for a decent filter for my Zetec. All the usual suspects were just that - suspect eg using a Renault 5 filter which is M20 on
a 3/4" ford oil filter thread - not the best. I ended up using a short but fat filter from a Ford XR4x4 V6 / Cossie 2WD. Ford oil filter code
EFL 298.
I found the MANN filter catalogue online to be very useful. You can supply the dimensions you want to use and it comes back with suggestions.
MANN Filter
Selector Here!
[Edited on 10/3/08 by SeaBass]
bob
| posted on 10/3/08 at 08:06 PM |
I used a Renault filter used on these models
R4 GTL 1984
R5 TL,GTL 1.1 1984
R9 1.1 1984
R11 1.1 1984
Part numbers
Fram 4546
Purolator L17603
coopers 107X
crossland 659
Schrodinger
| posted on 10/3/08 at 08:50 PM |
I used one from one of the smaller Zetecs 1.6 IIRC. I just went into the local Ford garage and asked for a shorter filter than the standard.
Keith
Aviemore
