Author: Subject: Type 9 Rebuild
davepro
posted on 15/3/08 at 07:52 AM Reply With Quote
Type 9 Rebuild
Hi Guy,
Does anyobe have a PDF of a web address where I can get details on how to rebuild/overhaul my type 9 gearbox.
Thanks in advance.
Regards
Dave Prouten
mookaloid
posted on 15/3/08 at 09:23 AM Reply With Quote
I'm not guy but I believe you need a special tool for removing and refitting the extension.
Otherwise it should be fairly straightforward if you just work methodically and keep all the bits in order.
If I recall the sierra V6 haynes manual has a procedure.
Mark
omega 24 v6
posted on 15/3/08 at 09:40 AM Reply With Quote
Hopefully U have email
posted on 15/3/08 at 10:37 AM Reply With Quote
Mark
IIRC you only need normal hand tools ? and a 5mm pin punch for drifting out the selector roll pins is useful .
mookaloid
posted on 15/3/08 at 10:44 AM Reply With Quote
Mark
I have not done it my self - however my source is a time served ford technician who I have known for many years.
Maybe as with a lot of things it's just a lot easier with the appropriate tool
mark
