Author: Subject: Replacement clutch help
neilj37
posted on 15/3/08 at 11:07 AM Reply With Quote
I think I may need to replace the clutch on my Vortx as I am starting to get some screaching under acceleration.
I am led to believe that the one that is fitted is a Sachs Heavy Duty Sierra one. Anyone know where I can get one from if I need to replace it??
MikeR
posted on 15/3/08 at 12:06 PM Reply With Quote
local motorfactor?
Standard trick is to try and get a diesel clutch as they are usually a little larger - although a tin top clutch for a 1.5 ton car in a .5 ton car should be ok i'd have thought.
If not, try burtons
posted on 15/3/08 at 01:01 PM Reply With Quote
Have you adjusted the clearance ? --- ie given it more free play.
whitestu
posted on 15/3/08 at 01:07 PM Reply With Quote
I amazed a clutch would wear out on a seven given the weight of the car.
I wouldn't have though a heavy duty one was needed.
Stu
