Bluemoon
posted on 17/3/08 at 12:58 PM |
Fuel filler pipe
I need a tight bend in my 2" fuel filler hose.. With superflex type pipe (i.e for example from CBS) how tight can I get?
Any photos?
The stuff is so expensive I don't want to by something that will not work!
Dan
worX
posted on 17/3/08 at 01:04 PM |
It's not ideal to go through tight bends and because it is expensive like you say why don't you go to a local engineering firm and get
them to just weld two pieces of ali together in the angle you need.
It will be a lot better when fuelling also...
posted on 17/3/08 at 01:09 PM |
Heres mine....
MkIndy7
posted on 17/3/08 at 08:24 PM |
Have you tried filling the car at a petrol station like that?
I would have thought the fuel would come spilling back out with the pressure.. or the pump would turn off almost immediately thinking it was full.
