bassett
| posted on 18/3/08 at 08:56 PM |
Diff and prop
Hi, im just setting about attaching my prop to the diff and engine. Bolt wise are they just thread locked with no nuts? I was going to use the serated
spring type washers on the prop to diff bolts should i do the same at the front?
Adam
Lee MacPherson
| posted on 18/3/08 at 09:01 PM |
I have just threadlocked mine in without using any special washer. The diff bolts are M10, 1mm fine pitch bolts.
bassett
| posted on 18/3/08 at 09:12 PM |
Cheers, we have the diff bolts, well 3 anyway as one seems to have gone walkies. How bout the front though?
Adam
stuart_g
| posted on 18/3/08 at 10:12 PM |
I just used the diff bolts with thread lock, no washers as per sierra.
The prop to engine adapter I used 12.9 grade cap head bolts with lock washer and thread lock.
| posted on 18/3/08 at 10:17 PM |
The tippex line is a good little tip. After my wishbone fell off  at speed, I went round the car with a tippex pen (5 for £1 from the local pound
shop) and marked the lines on all the nuts and bolts. A quick pre-blat check now takes minutes....
bassett
| posted on 19/3/08 at 12:17 AM |
Thanks guys, just what i was thinking but always best to be sure with these vital components.
Adam
