gregf27
| posted on 20/3/08 at 11:22 PM |
vx redtop to ford g/box ??
Can anyone identify the below g/box?? (one on the right - next to a pinto bellhousing)
I bought it a while ago now from e-bay for £100
it was advertised as a vx to ford type 9 gearbox, but it wasnt until I came to do my pinto - XE conversion that I realised it wasnt!!!
first off the clutch cable hole is missing, then I noticed the bolt hole gaps are different, and the hole in the middle is of a smaller diameter than
the type 9??
I suppose with a bit of modification it can be made to fit the type 9 (- I have even made a clutch cable bracket for it , that mounts to the engine
block)
but i ended up buying another one from yukspeed!!
so this one is surplus - any offers u2u me
as to its correct ID I havent a clue , please feel free to reply !
may be going back on e-bay!!!
[img][/img]
TOO BADD
| posted on 21/3/08 at 11:42 AM |
If you are asking about the bellhousing on the righr it is an XE to Type 9
gregf27
| posted on 21/3/08 at 12:53 PM |
unfortunately its not a type 9 to xe
that's why I bought one from yukspeed ,
as it wouldnt fit.
bolt holes are different.
NS Dev
| posted on 21/3/08 at 06:49 PM |
I am stumped.
if I were you, do a net trawl for pics of the cossie/mustang T5 gearbox (borg warner)
There is a bellhousing available to fit the XE to those, might be one??
Its similar in fitting to the type 9, but not the same, just like you pic!
Steve Morten
| posted on 21/3/08 at 10:31 PM |
It looks like it might be to fit the ford Type 3 /2000E gearbox they both use the same mounting holes.
