Beardy_John
| posted on 21/3/08 at 07:30 PM |
Identify this Carb
Evening all. Here's a tea time challenge for you.
Finally started stripping down my 1.6 sierra today (while dodging showers) and found my carb dosent match either of the ones in my Sierra Haynes
manual. All I know is its got "Weber" writen in about 10 diferent places. Any ideas what type it is??
pic_linky
  Un-identified Carb
[Edited on 21/3/08 by Beardy_John]
DRC INDY 7
| posted on 21/3/08 at 07:37 PM |
Its the economy carb that was used on the pinto emax engine
it all depends on your funds the carb will be ok to use unless you want a dgav weber carb
Puddle Dodgers Club
Beardy_John
| posted on 21/3/08 at 07:46 PM |
Maybe I need an newer version of the haynes manual! Is the DGAV a direct replacement?
snapper
| posted on 21/3/08 at 09:22 PM |
If the engine and carb came together then it is probably best practice to go to SVA with what you have and upgrade at your leasure
I eat to survive
I drink to forget
Beardy_John
| posted on 21/3/08 at 09:44 PM |
Sounds like sensible advice, but where can I get an air filter to fit it. Dont think the standard airbox is going to fit somehow
robinj66
| posted on 21/3/08 at 10:28 PM |
The closest I can find to your pic is :-
Weber 30/34 DFTH (stamped into base flange - tag would read Weber 85 HF DA G 5 E 20)
or
Weber 28/30 DFTM (stamped into base flange - tag would read - Weber 89 SF CC 2549 UK )
but neither were fitted to 1600 engines as standard
Beardy_John
| posted on 22/3/08 at 06:37 PM |
Robin, those are the nearest ones I could find too. It does have a tag on it but is there anywhere to look up the number?
