sprouts-car
| posted on 24/3/08 at 10:49 PM |
CVH engine height
I know this has probably been done to death by now, but looking at all previous posts i couldn't find the answer.
I'm building a 1.8 cvh in standard chassis and need to know how far below the chassis rail the sump should be (am i right in thinking that it
should be below)?
DavidM
| posted on 24/3/08 at 11:43 PM |
The book says the sump should be an inch below. I have mine set at 1 3/4" below and have had no problems with speed bumps etc.
westcost1
| posted on 25/3/08 at 12:26 PM |
Hi there spouts car i am using an xr2i cvh engine in my car which has a standard chasse you will probably need to chop the sump down a bit to get good
ground clearance as i have done my sump it is now the same height as the lowest part of the type 9 gearbox and the top of the rocker cover is about
5mm from the bonnet ill put some pics in my archive for you to see what it looks like. If you use a type 9 gear box mount from Westfield and mount
that on the floor of the chasse that should give you the height of the engine if everything is kept parallel to the ground. If you have efi it will
stick out the top of the bonnet like mine.
have a look at this thread this is what my sump looks like in the last pic http://www.locostbuilders.co.uk/viewthread.php?tid=82088
[Edited on 25/3/08 by westcost1]
