lukefab
| posted on 24/3/08 at 10:59 PM |
Diesel engine gearbox
Hi all,
Short and sweet question.
Will the ford type 9 gearbox fit a Sierra diesel engine without too many problems?
Keith
blakep82
| posted on 24/3/08 at 11:08 PM |
sierra diesel clutch plate is used to mount to a a vauxhall engine.... so i assume so with the right bellhousing
ooh, i think it might just be one particular engine size though
[Edited on 24/3/08 by blakep82]
________________________
bigrich
| posted on 24/3/08 at 11:10 PM |
1.8td sierra had a type9 as standard (long input shaft version). so yes it can
Chippy
| posted on 24/3/08 at 11:26 PM |
Only type 9's that will fit diesel engines, are the ones that come from the deisels, and the V6 box, as you need the extended shaft. Ray
Doh! must learn to type faster.
[Edited on 24-3-08 by Chippy]
lukefab
| posted on 25/3/08 at 06:41 AM |
Thanks for the answers, I thought there was a difference, but didn't know what it was.
Thanks again for your help.
Keith
MKMike
| posted on 25/3/08 at 04:01 PM |
I'm using a type-9 of a 1.8td sierra for a zetec, it seems to fit (eventhough I haven#
Is the shaft length ok for this?
| posted on 25/3/08 at 06:53 PM |
First gear may be very low. Petrol type 9s have a low enough first.
snapper
| posted on 25/3/08 at 09:11 PM |
Not much information on the diesel type 9 but from what i can gather they can cope with 155 ft/lbs of torque 145 bhp the V6 box a little more.
The ratios as far as i can tell on the diesel derivative has a very low first about 3.9 to 1 first, standard ratios 2nd 3rd 4th and a long 0.8 5th
gear.
It also has the longer input shaft so if fitting to the Pinto or Zetec needs the Caterham spacer between box and bellhousing.
It is one of the least ideal ratios available in type 9 format, unless you are running a 3.38 or 3.14 diff or cartwheels then 1st will be next to
useless, if you use the 3.38 or 3.14 diff with an engine with a 7000 red line or less then 5th and even 4th will be way to long.
I eat to survive
I drink to forget
NS Dev
| posted on 25/3/08 at 11:07 PM |
........and another fact for the pop pickers, though i've never seen it said by anybody other than me on here, is that the sierra 2.3 diesel box
had bigger and stronger cast bronze selector forks. I have had both types side by side and the ones from the diesel box are considerably bigger.
unfortunately I gave them to a mate for his tran-x box in his rally car as his need was greater so have no photos!
MKMike
| posted on 26/3/08 at 11:33 AM |
I have the Zetec and the gearbox bolted together at the moment (temporary for making engine mounts etc. with no spiggot bearing) and it seems to fit
just fine without spacers or clutch.
will there be a problem when I fit the bearing and the clutch?
