Author: Subject: Landy back propshaft
r1_pete
posted on 26/3/08 at 10:52 AM Reply With Quote
Anyone know if the landrover discovery back propshaft has a sliding joint in it? Just got my MT75 propshaft flange from Bailey Morris, and its the larger 27mm UJ fitting so looking for a locost way of building up a prop.
Mr Whippy
posted on 26/3/08 at 10:53 AM Reply With Quote
yip, front and back
their just a Defender with another body
[Edited on 26/3/08 by Mr Whippy]
TGR-ECOSSE
posted on 26/3/08 at 10:54 AM Reply With Quote
yip, front and back
I was going to say that!!!!
You have to be quick to get a reply in before Mr Whippy
[Edited on 26/3/08 by TGR-ECOSSE]
Mr Whippy
posted on 26/3/08 at 11:03 AM Reply With Quote
mark chandler
posted on 26/3/08 at 01:56 PM Reply With Quote
Thats what I used on mine.
Just make sure it slides freely, later ones have a nylon cover on the splines which is good, however sometimes the shaft below this jacket starts to rust causing the splines to lock solid.
NS Dev
posted on 26/3/08 at 11:25 PM Reply With Quote
I have some nylon sheathed landy propshaft ends if they are any use, removed from their tubes ready to be welded into new ones
