Author: Subject: RV8 bottom hose
Scotty
posted on 27/3/08 at 07:50 AM Reply With Quote
RV8 bottom hose
hi all
with the alternator fitted below its bracket, am i right in thinking there is an original one-piece hose for this set-up?
ie hose out of engine, 90 degree bend down away from alternator then 90 degree bend out towards radiator (rather than patching a hose out of several bits)
have tried rimmers but they didnt seem too helpful at the time
if there i one, would appreciate a part number and supplier if possible
thanks in advance
PLEASE NOTE! All comments made by this person are to be considered "Tongue in Cheek" and are not meant to be taken seriously in any way - so there!
robinj66
posted on 27/3/08 at 11:31 AM Reply With Quote
no picture I'm afraid but here is the part number etc from Rimmer Bros
http://www.rimmerbros.co.uk/cgi-bin/rimmer?fin dpart&PartID=GRH538&Page=rover/sd1/cool-heat
[PS this is for the 3500 manual SD1]
[Edited on 27/3/08 by robinj66]
kenton
posted on 27/3/08 at 05:51 PM Reply With Quote
I used a single length of flexable hose from CBS its corrigated on the outside but smooth on the inside. Used the same for the top hose.
The standard sd1 hose would not fit (i am using a luego rad with the outlet in the middle.)
[Edited on 27/3/08 by kenton]
