Author: Subject: valve adjustment
HAL 1
Builder
Posts 226
Registered 5/2/06
Location bolton
Member Is Offline
Photo Archive Go!
Building: Built haldane 100, retirement project Marcos GT
posted on 30/3/08 at 05:27 PM Reply With Quote
valve adjustment
situation came up yesterday when me and mate talking about valve adjusting ( sad i know ) I'd been told that if valves were rattling then adjust them up regardless of the manufacturers settings till they just about stop, he'd been told that if in doubt let them rattle, better too loose than too tight, what do think ?
jacko
posted on 30/3/08 at 05:33 PM Reply With Quote
Your mate is right let them rattle to tight and the edge of the valves will burn [ melt ]
daviep
posted on 30/3/08 at 05:39 PM Reply With Quote
If the clearance is set correctly then they don't rattle in my experience.
Davie
Mark G
posted on 30/3/08 at 05:45 PM Reply With Quote
tolerances change alot when the engine warms up aswell so best not to adjust the play out.
either leave them be or adjust them to the manufacturer's spec.
posted on 30/3/08 at 06:22 PM Reply With Quote
No keep to the engine (or cam manufacturers )spec -- if the clearances are too close it will sap the power and burn the valves.
On modern engines valve noise can often be due to sticking hydraulic tappets or the use of the incorrect grade of oil (with hydraulic tappets using too thick an oil leads to problems).
[Edited on 30/3/08 by britishtrident]
