Author: Subject: st170
quinnj3
posted on 3/4/08 at 09:37 PM Reply With Quote
st170
hi lads
I'm not going to be building for a while, i might start another post explaining why later.
Anyway i'm really thinking over an engine choice for a locost type car. Just thinking.
What is the best gearbox to attach to an ST170 engine? can it be done relatively cheaply? There is a few other engine applications i've been looking into but i think the ford set up is the most straight forward for a first build.
I've been contemplating a subaru 2.0 boxer turbo, a honda prelude 2.2 (but that is definatley out), various bike engines for all out blasts, a honda legend v6, omega v6 and maybe rover v8. You see what i mean. It is not easy to choose and i believe that a build takes a steady mind to complete properly. With all this choice how could i be satisfied with choosing any 1 of them. I'd start maybe with a car and half way through think well maybe a gsxr would be nice! Help!
my aim is to build my own locost wether it takes me a week or 10 years to get started, i'm sure i will sometime
posted on 3/4/08 at 09:42 PM Reply With Quote
Before you choose an engine you better sort out what you will be using it for mainly IMO then rule out the cons from there.
First con is expense - may rule out BEC.
Is noise/revs an issue - rule out BEC
If it out and out fun then BEC...
Some of your engine choice are a bit "new" so be prepared for a bit of trouble as you may well be one of the first and pioneers often take longer and frequently incurr more expense so chose wisely.
quinnj3
posted on 3/4/08 at 09:52 PM Reply With Quote
noise is not a problem, the more the merrier. But i would like to be able to relax and just cruise, as well as some of those more exciting runs. I don't like a sloppy gearbox in a car too, just ruins the experience in my view. My old honda has a very tight, smooth and fast gearchange keeping progress swift. i did own a pinto sierra a couple of years ago and thought the gearbox very sloppy. Didn't like it. I think the sequetial bike 'box would definatley be a plus here. Subaru turbo would be fast, smooth and rumbles but is also expense and probably some fancy electronics to mess with. The st engine is basically a duratec, a common enough engine in kit cars, so this one would probabaly be the simplest and possibly cheapest of all.
stig mills
posted on 3/4/08 at 10:07 PM Reply With Quote
Coming back to the st170, that is the same block as a 2.0 zetec so you can stick an mt75 on it no probs. I use them as a middy set up with the getrag 6 speed. The boxs fetch good money if your doing a north south config and dont need the east west unit.
Flick
posted on 3/4/08 at 10:23 PM Reply With Quote
Originally posted by quinnj3. But i would like to be able to relax and just cruise, as well as some of those more exciting runs.
I thought that after I built a BEC. So I sold the BEC and bought a CEC with a tuned pinto......Then one with a zetec.....
The 'relaxing and cruising' soon wore off.....back to BEC.
austin man
posted on 3/4/08 at 10:25 PM Reply With Quote
I have read that Raw are doing a close ratio box this may fit as they have also fitted Zetecs the cost was an additional £750 may be worth a call
posted on 4/4/08 at 08:09 AM Reply With Quote
If you're into long quiet runs then go CEC - the spirited runs will still be fun
When you get bored you can always fork out again and change the engine, but be warned, it's not as simple as it sounds going from CEC to BEC.
You may as well forget the relaxed cruising - buy a tin-top for that. Just go BEC and have more fun with a HUGE smile.
posted on 4/4/08 at 08:30 AM Reply With Quote
Go for a compromise
ST1100
or if you're into bleeding-edge and want an engine that no-one else has done use a ST1300.....
Whisper quite if you use the bike cans. Noisy as beans if you don't Big slug of torque and enough BHP to get your mojo flowing.
But then I'm biased....
The only thing I don't like about the ST1100 engine is the belt whine at idle. Soon that will be drowned out by the addition of a supercharger belt....
posted on 4/4/08 at 08:56 AM Reply With Quote
Originally posted by BenB
Go for a compromise
ST1100
I had this exact thought the other day. Not exactly a hyper performance engine compared to the superbikes, but perhaps more suited to everyday road use i a locost and I suspect the gearbox and clutch are pretty robust.
Do you know what price and availability of ST1300 engines is like? I guess the riders of these bikes don't tend to throw them down the road as often as superbike owners
