jlparsons
| posted on 5/4/08 at 10:21 PM |
diy lectric bec shift
Anyone done a DIY electric shifter for a bec? It seems the ones on the market are a bit dear, was thinking of a locost option. I'm not talking
about full-throttle upshifts, just an actuator to throw the gear lever fore/back when you press a button each side of the steering wheel.
Solenoid + control box + paddles/buttons = shifter?
Any resemblance to real persons, living or dead is purely coincidental. Some assembly required. Batteries not included. Contents may settle during
shipment. Use only as directed. No other warranty expressed or implied. Do not use while operating a motor vehicle or heavy equipment. Subject to
approval, terms and conditions apply. Apply only to affected area. For recreational use only. All models over 18 years of age. No user-serviceable
parts inside. Subject to change. As seen on TV. One size fits all. May contain nuts. Slippery when wet. For office use only. Edited for television.
Keep cool; process promptly.
mark chandler
| posted on 5/4/08 at 11:52 PM |
I have not made one myself but have seen them constructed using ford central door locking solinodes.
Should be pretty simple if you are changing up only, something for the summer.
Regards Mark
gingerprince
| posted on 6/4/08 at 09:25 AM |
Why not buy a proper one?
One on ebay at the moment, currently 100 quid - tend to go for about 150 or so second hand, that's what I got mine for.
http://cgi.ebay.co.uk/Kliktronic-M-cycle-button-press-gear-changer-shifter_W0QQitemZ300212641432QQihZ020QQcategoryZ25623QQssPageNameZWDVW
QQrdZ1QQcmdZViewItem
Certainly better than paying 500!
[Edited on 7/4/08 by gingerprince]
jlparsons
| posted on 6/4/08 at 10:19 AM |
Wow, that's a lot cheaper, and at that price you're absolutely right.
Quick related question while I have your attention - how do you find neutral with a clicker system? Does it have to do a half-throw or do most
superbike engines simply shift up one click from 1st and presto, neutral? (never ridden anything bigger than a 125... )
blue2cv
| posted on 6/4/08 at 02:58 PM |
Apparently a practiced dab of the button is the way to find neutral, on mine i will also have a simple cable operated neutral lever, hence extra hole
in bellcrank
