triumphdave
| posted on 6/4/08 at 11:07 AM |
XE cambelt
Do I need a special tool to tighten the cambelt on an early XE,or can you do it by feel?
[Edited on 6/4/08 by triumphdave]
Mark G
| posted on 6/4/08 at 11:25 AM |
I haven't done a belt on an xe for a few years now but I think there's a needle on the tensioner that points to a marking on the back of
the tensioner (a marking for new and used). You tighten it with a 5mm allen key and turn the engine over a few times and time it up again and check
the tension.
If its ok, start the engine up and run for a min or 2. Then stop the engine, time up and check the mark again.
ned
| posted on 8/4/08 at 09:22 AM |
no tool required, tighten the offcentre/cam type tensioner pulley and check tension by twisting the belt. pretty sure the haynes tells you how much it
should twist by when under correct tension. just about 80-90 degrees from memory but i could be wrong.
Ned.
beware, I've got yellow skin
