MKMike
posted on 7/4/08 at 05:04 PM |
Phase 3 Zetec Sump
Does anyone know if you can buy a shortened phase 3 sump and pickup? (just the lower steel part)
madteg
posted on 7/4/08 at 07:12 PM |
I know you can fit a silvertop sump and pick up pipe to a phase 3 because i have, because it looks a bit of a pip cutting a phase 3 down, hope this
helps.
scutter
posted on 7/4/08 at 07:19 PM |
Yes fella you can, Trust me the engine's cleaner now it's in
![](/galpreviews/2sale 001.jpg) ![phase 3 sump](/gallery/2sale 001.jpg) phase 3 sump
ATB Dan.
MKMike
posted on 7/4/08 at 09:02 PM |
What way did you baffle it?
I was thinking of somthing similar, how did it work?
Any problems when you ran the engine?
What volume of oil did youget into it?
scutter
posted on 8/4/08 at 01:21 PM |
1, I put 2 laterial baffles in it, plus drilled drain holes in the raised section that i extended into.
2, I honestly can't say as i haven't run it yet.
3, Ditto
4, The volume is the same as i extended to aft section to make up for what i removed.
![](/galpreviews/2sale 002.jpg) ![Zetec sump 2](/gallery/2sale 002.jpg) Zetec sump 2
ATB Dan.
MKMike
posted on 8/4/08 at 01:39 PM |
Cheers for the info.
I was going to buy the tiger era one or one of the modified ones but they are mad money, so I think I'll go with a chop on the steel part
instead.
Do you have any photos of the inside?
What depth will you have hanging below the chassis?
scutter
posted on 8/4/08 at 10:15 PM |
No sorry I didn't photo the inside.
It's hanging 30mm below the chassis rails, level with the gearbox bellhousing.
ATB Dan.
