Author: Subject: BHP & Torque figures for XE to generate VE table
Steve Lovelock
posted on 10/4/08 at 07:17 AM Reply With Quote
I need these figures and at what RPM they occur to use the VE table generator on my ECU. I know the orginal figure for the XE was 150 BHP but I have no idea what revs this is generated at.
martyn_16v
posted on 10/4/08 at 08:22 AM Reply With Quote
I wouldn't bother with the VE generator, it's useless with 'peaky' engines (i.e. anything with the max torque close to max bhp rpm, i.e. anything not an american v8). If you do try it you'll probably find it will compress a normal looking VE table into the top half of the load range, and leave the bottom half empty.
Steve Lovelock
posted on 10/4/08 at 09:10 AM Reply With Quote
Well I need to start somewhere on the VE table, unless anybody has one I could use?
Jenko
posted on 10/4/08 at 09:53 AM Reply With Quote
Can someone explain where to start generating a VE table if the tool is not so good - Must admit, I used the tool, and it came up with a table that really did not look too good.....Any help on calculating a VE table would be welcome....
Paul.
ned
posted on 10/4/08 at 11:29 AM Reply With Quote
My engine is not standard but I've got the graph from my rolling road session in my photo archive..
Ned.
beware, I've got yellow skin
