Author: Subject: 05 R1 oil adapter thread sizes?
nitram38
posted on 12/4/08 at 09:10 PM Reply With Quote
I want to pick up my pressure gauge (capillary type) from the main gallery end plug.
The original aluminium plug has a hex key which makes it too thin to tap.
I have a brass adapter that seems to go into the thread but only about 3 turns. (this has an internal thread for a 1/8 npt brass male end).
First, does anyone know the thread size of the gallery? I have been through the R1 04 manual and can't find anything other than the part number for the oil pressure test adapter.
I don't want to wind the brass adapter in any further as it may cause the thread in the gallery to split, so I am not sure if it is the right one.
I would rather get the correct one for the job.
Cheers Martin
adithorp
posted on 12/4/08 at 09:19 PM Reply With Quote
Durite part No 0-523-98 is a set of 3. 1/8npt M14 M16 M18 all x1.5
I bought this set through work as I wasn't sure of the thread and I've got the small and big one left so...
M16x1.5
adrian
yorkshire-engines
posted on 12/4/08 at 09:21 PM Reply With Quote
Hi Martin my gauge (electric) came with an adapter that fitted my r1 perfectly im sure that yours is the same so it should be ok but if not i had some made a few weeks ago that do fit they cost me £10 each though if you want one ill post one out
cheer s malc
yorkshire-engines
posted on 12/4/08 at 09:23 PM Reply With Quote
adi how much is ths kit and if its below a tenner im gonna scream
adithorp
posted on 12/4/08 at 09:34 PM Reply With Quote
hmmm, well. It came in amongst a big order of other stuff for work and I don't think I ever paid for it...oops!
I can find out on Monday.
adrian
nitram38
posted on 12/4/08 at 09:56 PM Reply With Quote
Just found this on ebay !
Based on your advice guys, I have bought a set for £6.84 including postage.
[Edited on 12/4/2008 by nitram38]
lsdweb
posted on 13/4/08 at 11:33 AM Reply With Quote
Good find! I paid that for one!
nitram38
posted on 13/4/08 at 01:21 PM Reply With Quote
The bummer is I just found one in the garage !
So I will be getting a brand new one for no reason at all
Anyone need a set ?
adithorp
posted on 14/4/08 at 12:29 PM Reply With Quote
Malc, I paid £5.72 +vat so £6.72.
adrian
