Author: Subject: Help
Stuart_B
posted on 13/4/08 at 03:56 PM Reply With Quote
Help
Hi all, tried to start my pinto with the bike carbs, and it kept kicking back. so then took them carbs of and fitted the old carbs, and it will not start up. so how can you time the engine up?
As well does any one know what the marking on the head should be for a 1.6 pinto?
As well what coulour should the rocker box been?
stuart
jacko
posted on 13/4/08 at 05:11 PM Reply With Quote
A bit more info would help
are you using a megajolt , modifide dizzy , what bike carbs , standard dizzy ?
Stuart_B
posted on 13/4/08 at 05:24 PM Reply With Quote
Hi, it is a 1.6 pinto, standard dizzy with a homemade bike carb manifold which sits a set of 1999 cbr600fx carbs, and an 1999 cbr600fx self regualting fule pump.
stuart
darrens
posted on 13/4/08 at 06:51 PM Reply With Quote
pinto's are notorious for kicking back if the spark timing (i.e dizzy) is too far advanced.
Stuart_B
posted on 13/4/08 at 07:01 PM Reply With Quote
Yes the engine is way to far advanced. So how can i time it to be correct?
thanks
stuart
[Edited on 13/4/08 by Stuart_B]
Paul TigerB6
posted on 13/4/08 at 07:52 PM Reply With Quote
Have you taken the distributor out at all?? I had a Pinto kicking back and dying within a second or two when it fired and found out i had the timing 180degrees out (on MegaJolt but same can be done with the dizzy obviously)
Stuart_B
posted on 13/4/08 at 08:00 PM Reply With Quote
The dizzy has not been removed by me at all.
darrens
posted on 13/4/08 at 08:03 PM Reply With Quote
turn it anti-clockwise by a few degs
Stuart_B
posted on 14/4/08 at 07:24 PM Reply With Quote
I alligend all the tdc up, and moved the dizzy, changed the leads to have the correct firing order. trun the key started a lot better, a few little tweaks with the dizzy and i am running on teh old carbs at the moment, but it is running better and starts up with a lot less effot. so 2mor will will ahve a go on bike carbs.
stuart
