graememk
| posted on 14/4/08 at 09:48 PM |
manifold glowing red
does yours ?
could my ignition timing be out if so which way ?
Volvorsport
| posted on 14/4/08 at 09:49 PM |
retarded
www.dbsmotorsport.co.uk
getting dirty under a bus
| posted on 14/4/08 at 09:55 PM |
quote: Originally posted by Volvorsport
retarded
He only asked a question - that's verbal abuse that is
graememk
| posted on 14/4/08 at 09:58 PM |
retarded
just spat my beer out pmsl
Volvorsport
| posted on 14/4/08 at 10:01 PM |
lol , KISS !
RazMan
| posted on 14/4/08 at 10:02 PM |
When my car was on the rollers the collectors on each bank were glowing a bright red which was scary at the time
With normal road use I would be surprised if they could get that hot due to the extra airflow - turbos however are a different story.
Raz
Miks15
| posted on 14/4/08 at 10:07 PM |
saw this earlier an thought it fits in nicely with this post! plus it looks cool after about 40 seconds ull start to see what i mean!
Link
graememk
| posted on 14/4/08 at 10:09 PM |
mine is turbo, is this normal or very bad
redscamp
| posted on 14/4/08 at 10:17 PM |
bike exhuasts glow if its dark enough to see them (hot enough to blue chrome)
RazMan
| posted on 14/4/08 at 10:26 PM |
Quite normal but usually after a good thrashing
Raz
graememk
| posted on 14/4/08 at 10:29 PM |
on right oh dear i've never taken mine above 3000 rpm pmsl
Mr Whippy
| posted on 14/4/08 at 10:59 PM |
red, mine tend to glow orange
Daimo_45
| posted on 14/4/08 at 11:53 PM |
Few of my mates have turbo tintops and they glow red when they're thrashed.
speedyxjs
| posted on 15/4/08 at 06:47 AM |
Your avatar seems to glow red if that counts
Mr Whippy
| posted on 15/4/08 at 07:54 AM |
I have plans....(queue the manic laugh   )
tegwin
| posted on 15/4/08 at 10:05 AM |
Thats a sign of a badly designed combustion chamber....
If you design the combustion chamber properly there is a flow of cooler air around the outside of the pipes diameter to keep the walls cool.... That
turbo wont last long...not long atall!
www.verticalhorizonsmedia.tv
| posted on 15/4/08 at 03:25 PM |
Yep -- On a non-turbo engine it is generally a sign of ignition is too retarded the excess het is caused by the combustion being incomplete before
the exhaust vavle opens as a result a higher percentage of combustion heat energy is rejected to the exhaust.
Turbos are a bit different and will get a buld up of heat after being thrashed which can cook the oil in the turbo bearing drastically shortening
turbo life..
With a turbo you should :
(1) Always allow the turbo to cool down after a hard drive -- ideally drive quietly for half a mile or so and allow to idle for up to a minute before
switch off.
(2) Use a top quality synthetic oil.
[Edited on 15/4/08 by britishtrident]
