bracey
| posted on 18/4/08 at 10:08 PM |
electrical pump on single carb
found serious wear on cam lobe for fuel pump (mechanical) will using an electrical pump cause any probs
facet solid state pump through regulator (what setting ,dont know)
to vauxhall varijet carb
will this cause probs because not running at engine revs ,will it overcome the carb ,flood it ??
its manta engine ohc
or do i need interupter pump etc
help and advise greatly needed
thanks
richard
UncleFista
| posted on 19/4/08 at 12:09 AM |
Should be fine, we ran a single carb on a Facet carb pump (blanked off the mech pump "hole" ) without a regulator with no problems at
all.
[Edited on 19/4/08 by UncleFista]
Tony Bond / UncleFista
| posted on 19/4/08 at 07:51 AM |
thanks
richard
Do you already have the fuel pump if not just get a lower pressure pump and ditch the regulator.
jacko
| posted on 19/4/08 at 09:21 AM |
how about a motor bike fuel pump carb zx9r or similar
| posted on 19/4/08 at 03:48 PM |
http://www.completeautomobilist.com/part/1337-12v/
http://www.completeautomobilist.com/part/1337-SR/
bracey
| posted on 19/4/08 at 07:07 PM |
it is the facet fuel pump ,got it in and found running at one psi after short accel it drained float chanber ,on 2 psi great
think all is good now
