Author: Subject: vw tdi over heating
tjoh84
posted on 20/4/08 at 04:40 PM Reply With Quote
vw tdi over heating
got a vw golf tdi just started over heating help needed please
iv check a few things
first it only over heats when driving but is fine on tick over
the fans kick in a run no prob
the water lebal is fine
oil is fine
not sure what it can be really any one here any ideas
its a 1.9 130 pd if that helps on a 02 golf
so dont want to be spending loads lol
posted on 20/4/08 at 04:50 PM Reply With Quote
Does the heater work when its overheating? if not it may be the water pump impeller faulty. Get it tested for head gasket failure? Possible thermostat failure ? blocked rad ?
tjoh84
posted on 20/4/08 at 04:52 PM Reply With Quote
sorry yea no no heating wel luke warm not like norm as i tride to see if that would bring temp down
froggy
posted on 20/4/08 at 04:53 PM Reply With Quote
plastic impeller on the pump has split done loads of them,all the replacemant ones are metal
tjoh84
posted on 20/4/08 at 04:56 PM Reply With Quote
is it costy job to have done roughf idea
posted on 20/4/08 at 05:00 PM Reply With Quote
Change the timing belt and tensioner while your at it . As said a lot of later VW water pump impellers are made of plastic and come loose on the shaft.
tjoh84
posted on 20/4/08 at 05:55 PM Reply With Quote
had new belt and put only 20k two year ago
R1 STRIKER
posted on 20/4/08 at 06:16 PM Reply With Quote
The guy that services my taxi changes the water pump when he does the cam belt. Says they are a common problem. From memory I think the kit was about £40. False economy not to do it whilst cam belt is off.
Ben.
DRC INDY 7
posted on 20/4/08 at 06:34 PM Reply With Quote
just done a passat diesel impellar had un- bonded on the water pump common problem
Puddle Dodgers Club
posted on 20/4/08 at 07:04 PM Reply With Quote
For the price of a belt it's simply not worth re-using one unless it's literally a few miles old.
