graememk
| posted on 20/4/08 at 10:42 PM |
engine retarded manifold glowing red
what would happen if the engine was to far advanced ?
Paul TigerB6
| posted on 20/4/08 at 10:47 PM |
Pinking, possibly holed pistons etc. Basically the head would get very hot anyway
Mark G
| posted on 20/4/08 at 11:06 PM |
if its after you've driven it hard for a while then its nothing to worry about.
If its just doing it on idle then you need to get your engine checked out.
stevebubs
| posted on 21/4/08 at 12:14 AM |
Get a timing light on it in some shape or form....
| posted on 21/4/08 at 07:02 AM |
Too much advance causes at best pinking at worst detonation.
Also too much advance also causes difficult starting, hunting at idle speed and can cause over heating.
[Edited on 21/4/08 by britishtrident]
smart51
| posted on 21/4/08 at 07:48 AM |
Too much advance would cause a loss in power because the pressure build up in the cylinder would happen before TDC. This would cause the engine to
slow during the compression stroke. Advance the ignition even further and you risk bending conrods.
Mr Whippy
| posted on 21/4/08 at 08:00 AM |
Honestly glowing manifolds are perfectly normal, especially the tubular ones. Gas temperature must be about 700-800degs, don't worry it's
not going to melt
graememk
| posted on 21/4/08 at 08:10 AM |
more worried about my £500 turbo.
Mr Whippy
| posted on 21/4/08 at 08:39 AM |
Y?
nib1980
| posted on 21/4/08 at 08:50 AM |
If it's a Nissan turbo I wouldn't worry there tested well beyond what you'll ever see.
Paul TigerB6
| posted on 21/4/08 at 10:46 AM |
Dont worry about the Turbo - but do worry about the engine if you suspect your timing is considerably out. Well worth getting this right from the
outset with a timing light etc as said. I borrowed one from the mechanic across the road and despite very carefully lining up the trigger wheel for
the MJ, was still 3 degrees out initially
graememk
| posted on 21/4/08 at 11:42 AM |
yes thats my worry that my trigger wheel is out
| posted on 21/4/08 at 12:18 PM |
You will run into serious detonation long before that stage.
