greglogan
| posted on 21/4/08 at 07:54 PM |
Fuel Pipe
Hi guys
what sort of pipe should I be using for my fuel pipe? Solid or rigid and what size?
Greg.
Women are meant to be loved, not understood.
LBMEFM
| posted on 21/4/08 at 08:54 PM |
I used 8mm copper micro-bore central heating tube from a plumbers merchant. then used flexi fuel hose for the conections, seem to work well. I asked
the same question as you and everyone seemed to agree that this is a good option.
[Edited on 21/4/08 by LBMEFM]
bassett
| posted on 21/4/08 at 09:50 PM |
Im using the same copper pipe flared at the ends and then Goodyear rubber fuel pipes with proper pipe clips.
MikeR
| posted on 21/4/08 at 10:27 PM |
do a search on my username and copper pipe. I've posted a number of times on the down side. Most people use it without a problem.
speedyxjs
| posted on 22/4/08 at 06:55 AM |
Just out of curiosity, can you use the same copper pipe you use for brakes?
