gsand
posted on 19/11/03 at 03:39 AM |
Engline mounting angles
How much of an angle can be placed on a modern engine? the reason i ask is because i am trying to keep the rear bodywork as low as possible (mid
engined car). I know that i can run my 4 stroke model aeroplane motor in any orientation, but how would this affect the sump and oil feed.
Regards, Glenn.
4st Insanity
Maybee i should start wearing a Welding mask.....
VinceGledhill
posted on 19/11/03 at 08:48 AM |
Could you not modify the sump and pickup?
Regards
Vince Gledhill
Time Served Auto Electrician
Lucas Leeds 1979-1983
Simon
posted on 19/11/03 at 09:40 AM |
Glenn,
As Vince says, main concern is going to be oil pickup, plus the fact the gravity will still be required to get oil to sump, so obviously you
can't lie it flat.
Next consideration is fuelling. If you're using carbs, you'll need a different manifold to keep the float chamber reasonably level. If
injection, you may get away with it.
HTH
Simon
[Edited on 19/11/03 by Simon]
posted on 19/11/03 at 11:33 AM |
Just remember that every road car is designed to cope with fairly severe up and down gradients - so a few degrees one way or the other shouldn't
make any difference!
gsand
posted on 19/11/03 at 11:59 AM |
quote: Originally posted by Simon
Glenn,
can't lie it flat.
HTH
Simon
Yeah, it should be too difficult to modify the pick p and the sump, and the motor will definately not be lying flat. I was thinking of 30-40 degrees
of vertical, leaning to the front of the car. And I would be using fuel injection...
Although all this would not be necissary if i could find a motor with a low enough profile (height) so it can fit under my bodywork, which will be
roughly the height of an XTR2 if not a little lower.
David Jenkins: Excellent point! Ya certainly got that right. But if i take up the allowable angle with the motor tilt, what is it going to do
when i actually go up and down gradients
Regards, Glenn.
4st Insanity
posted on 19/11/03 at 12:43 PM |
quote: Originally posted by gsand
...I was thinking of 30-40 degrees of vertical, leaning to the front of the car. And I would be using fuel injection...
Glenn,
I didn't realise that you meant so many degrees off horizontal!
The main problem you'll have is the oil in the sump. Apart from picking up the oil and pushing it through the oil-ways, the bottom of the
cylinders get a lot of lubrication from the crankshaft splashing the oil around the bottom of the bores. Also, you would have to make sure that the
lowest piston doesn't come up against the oil in the sump.
James
posted on 19/11/03 at 01:03 PM |
Glenn,
Have you thought about what engine you're going to use?
Some motorbike engines I've seen (admittedly installed in cars) are at quite an angle so maybe one of them would be an option?
HTH,
James
ned
posted on 19/11/03 at 01:13 PM |
A boxer engine/flat four as in a subaru/some alfa's/porsches would be low if they'd fit?!
Ned.
beware, I've got yellow skin
gsand
posted on 20/11/03 at 01:41 AM |
Yes that is a very good possibility, but then i need to go through the hassle of finding a suitable and cheap transaxle gearbox...
