Author: Subject: Zetec and CVH
sprouts-car
posted on 23/4/08 at 08:21 PM Reply With Quote
Zetec and CVH
Are the engine mounts on the Zetec and CVH the same design, ie bolt pattern and size?
Cheers in advance,
Chris
stevebubs
posted on 23/4/08 at 11:38 PM Reply With Quote
no. L/H mount at least is different. Think the R/H mount may be interchangeable, though.
posted on 24/4/08 at 06:22 AM Reply With Quote
Above is correct BUT
1.8 RWD CVH mounts won't fit a FWD CVH or a Zetec as the FWD engines don't have the required bosses on the block casting.
[Edited on 24/4/08 by britishtrident]
ChrisW
posted on 24/4/08 at 01:04 PM Reply With Quote
The back one, if viewed in a FWD car, has the lowest of the three bolts in a different place. Some people bodge it with just two, but you should really cut and shut the mount to move the hole to the right place.
Chris
