RichardK
| posted on 27/4/08 at 08:15 PM |
pinto distributor removal
Hi Ladies and Gents
I've seen a few people that have capped off the dizzy, obviously leaving the drive to the oil pump in situ, anybody who has done this mod and
has a picture or two on how they did it would be most welcome as would any other advice, bearing part numbers etc
TIA
Rich
Gallery updated 11/01/2011
RichardK
| posted on 27/4/08 at 08:31 PM |
Thanks Rob, thankfully I have a lathe so shouldn't have to learn the hard way Did the bearing come with that rubber cap and does it weap oil
at all?
Rich
DarrenW
| posted on 27/4/08 at 09:17 PM |
Mines not as neat as Robs but essentialy i cut the ali body off the top that houses the points. Filed the stud round. Cut shaft off a bit. Net result
is full shaft bearing is intact, therefore no secondary bearing needed. Works fine.
Benzine
| posted on 27/4/08 at 10:07 PM |
quote: Originally posted by robocog
Pics
First (on mine)
Image deleted by owner
Very tidy job! Slight hijack, what are those things called that go between the oil filter and the engine? Are they to get an oil feed for an oil
cooler or a turbo?
[Edited on 27/4/08 by Benzine]
RichardK
| posted on 6/5/08 at 08:24 PM |
OK Rob here are my efforts!
Measurements on images and a couple of grub screws retain the bearing.
Rich
| posted on 6/5/08 at 08:45 PM |
If it's anything like the piece I turned down for DaveFJ's Pinto engine, it's an extremely tough and gnarly material! I had a lot
of trouble getting anything like a decent finish.
(can't remember if that was the sleeve or the shaft though...)
[Edited on 6/5/08 by David Jenkins]
RichardK
| posted on 6/5/08 at 09:04 PM |
I must have been lucky as it seemed to work with no problems at all on the lathe although I do have tunston carbide tips to work with which will help
as well as a decent cutting fluid.
I did cheat with the first bit though
Regards
Rich
[Edited on 6/5/08 by RichardK]
