Author: Subject: sump questions
Miks15
posted on 29/4/08 at 07:21 PM Reply With Quote
sump questions
As some of you might know ive been about to chop my sump. And im gonna have a go at welding it myself. But i need the right wire obviously. What grade wire do i need?
Plus i need to get some ally plate to finish it off. What grade ally do i need? and what thickness would you recomend?
owelly
posted on 29/4/08 at 07:29 PM Reply With Quote
Can you use a piece of the same sump to fill in the gap? Perhaps a piece of the bit you've just cut out?
Normal ally MIG (or TIG) wire worked for mine.
http://www.ppcmag.co.uk
mad4x4
posted on 29/4/08 at 07:35 PM Reply With Quote
Where can you buy Zetec sumps - already chopped??
Scot's do it better in Kilts.
Miks15
posted on 29/4/08 at 07:41 PM Reply With Quote
i was going to use the bit ive just chopped out, but there are some wierd shapes on my sump and it will be tricky to get it to line up again properly. Plus im going to extend it so i will need some plate for that. I asked someone and they asked what grade wire i was after. anyone know?
posted on 29/4/08 at 09:01 PM Reply With Quote
4043 seems to be the generaly recommended grade for MIGing.
Miks15
posted on 30/4/08 at 06:39 AM Reply With Quote
cheers mike
paulf
posted on 30/4/08 at 08:32 AM Reply With Quote
Have you migged ally before? Unless you have an expensive mig set then you will struggle a lot , the wire bunches up and jams so you really need a mig with a torch with its own built in feed rollers.
Mig also tends to be porous , so ideally prepare it all then find someone to tig weld it for you.
Paul.
